It is currently Sun Aug 17, 2025 1:19 pm
 Post subject: rattling fretboard?
PostPosted: Fri Apr 23, 2010 12:27 pm
First name: Heath
Last Name: Blair
City: Visalia
i just finished binding a fretboard and now when i tap on it, it rattles. anyone else experience this? the binding joints all look tight and ive cleaned the slots out. no frets obviously. any help? thanks in advance.
sweat the small stuff.
 Post subject: Re: rattling fretboard?
PostPosted: Fri Apr 23, 2010 1:01 pm
Most likely the truss rod, if you're using one. Try tightening it just a touch and see if that changes anything.
PostPosted: Fri Apr 23, 2010 1:37 pm
First name: Heath
Last Name: Blair
City: Visalia
i just radiused the board and the rattle went away. maybe just some glue or something that got planed/sanded away. either way, no more rattle. idunno
thanks for the tip anyway, pat.
sorry for wasting forum space with nonsense.
PostPosted: Fri Apr 23, 2010 1:44 pm
Last Name: Abercrombie
'Things that go bump in the night....and then go away'
It's happened to everybody- no worries.
PostPosted: Fri Apr 23, 2010 6:28 pm
First name: Heath
Last Name: Blair
City: Visalia
what in the world?! its totally back. i must be going crazy.
PostPosted: Fri Apr 23, 2010 6:45 pm
First name: Heath
Last Name: Blair
City: Visalia
just to be clear, this is an unfretted board that is NOT attached to the neck.
PostPosted: Fri Apr 23, 2010 6:50 pm
Maybe it's cracked somewhere?
PostPosted: Fri Apr 23, 2010 11:43 pm
Last Name: Shaw
City: Philadelphia
I was just going to suggest what John suggested. So I'll suggest loose inlay maybe. But i still think john got it right....Mike
PostPosted: Sat Apr 24, 2010 5:11 pm
Heath wet it with some naptha or alcohol. That should make a crack stand out. Don't forget the edges.
PostPosted: Sun Apr 25, 2010 12:55 am
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
If it's the truss rod, there's a silicone you can inject that's an instant cure. It has no effect on the function of the rod, just stops the rattle.
PostPosted: Sun Apr 25, 2010 1:39 am
It's not snake wood by any chance is it??
Sorry :roll:
PostPosted: Sun Apr 25, 2010 2:10 am
That was not very helpful :|
If you hold it at the sweet spot up next to your ear and tap it and you get no real sustain and more of a rattle, I recon it's a safe bet to be a crack. If it hisses at ya, drop it and run away quick.
PostPosted: Sun Apr 25, 2010 3:12 am
Country: Romania
Kim, this should make it to the luthiery jokes collection laughing6-hehe
Sorry Heath oops_sign
Build log
PostPosted: Sun Apr 25, 2010 4:19 pm
Last Name: Shaw
City: Philadelphia
Well the fingerboard is not attached to the neck yet but silicone is recommended prior to installing the truss rod. A small bead at the bottom of the slot before installing the truss rod. I recommend 100% silicone which doesn't harden like silicone caulk.
PostPosted: Sun Apr 25, 2010 10:32 pm
First name: Heath
Last Name: Blair
City: Visalia
ha! thats pretty funny. no, its not snakewood. it is mad rose though, and that can get crack happy i suppose. i havent had a chance to fiddle around with it anymore, but it rings long and loud when i tap it. im thinking theres just got to be something hung up in one of the fret slots. ill wet it down with some mineral spirits when i get a chance. see what i can see. ill probably dig around in those fret slots some more too. thanks to all for the advice and ill get back to ya with the findings.
Users browsing this forum: DennisK and 27 guests
